So as some of you probably know, I'm a big fan of compound twin turbo setups. I've had several different kits, and I have always really liked them. The shop truck currently has an S480/S364.5 with fairly tight turbine sides on both turbos. It is a blast to drive on the street and makes good power.
You may also remember that a couple of months ago I broke the crank in the stock motor in the truck and decided to pull the built motor out of the dumpster. The motor is exactly as it was in the dumpster except I removed my 12mm CP3 for dual stock pumps, and I removed the single S472 to install my twins. The motor out down 970 on a chassis dyno (I know, dyno numbers) on a 2500 uS tune with 100% injectors, but I was never able to work out all the bugs on the new setup before I pulled the motor out to verify that power.
So fast forward to Saturday. I took the truck to the track and made one pass on a 2600 uS tune (same injectors I used in the dumpster) and trapped 125 mph. According to CompD calculator (which has always seemed pretty accurate to me), that's about 800 hp to the ground. With a stock motor and 40% injectors (same pulse width that actually peaked full fuel higher in the rpm band), I was able to trap almost 120 mph which equates to 700 hp. I was really expecting to be in the 130+ range and in the 10s, but I was a little disappointed.
So here's what is on my mind, I'm thinking maybe the tighter turbine housings and smaller turbine wheel in the valley turbo is causing flow problems and killing power. I'm seriously thinking about removing my twins and bolting on the 472 in their place. Does this sound crazy to anyone else? I will probably do it either way because I've never run a larger fixed geometry turbo, and I would like to see what it is all about. That said, I would love to hear opinions from others on whether or not you think I'm expecting too much out of the truck or if you agree that maybe my setup is killing top end power.
