Dorman body mounts dont fit...
Dozerboy
4,918
497
TX of course
I use Fluid Film religiously here in OH, LPS #3 is a more "permanent" option that has a waxy type coating. I looked at the PB Blaster product, pretty pricey. Never got into the MSDS to see what the base material was
It last a lot longer IMO. Google it there is a guy that did a video and likes it better then Fluid Film.
gassux
362
repairgeek on YT has great videos on fluid film and pb blaster. I've found the pb blaster to be more self leveling than FF
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,517
501
Central OH
Pulled up the SDS on the PB Surface Shield, contains distillates and lanolin, not too dissimilar from Fluid Film / WoolWax / PFC. Which will all wash away under heavy salt spray exposure. That LPS#3 is probably the only product I've ran across that will apply easily and soak into metal, but when cured leaves a very durable waxy coating. It's mostly petroleum based with xylene I think
2,215
I remember reading a while back about people successfully dissolving paraffin wax in gasoline and spraying it on the undercarriage and frame. The gas evaporates leaving the wax behind. The gas also facilities the wax penetration into the cracks and pores. Supposedly works well against salt and it easy to apply. Dirt cheap too. Draw back is the small until the gasoline is gone
Reactions: Dozerboy
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,517
501
Central OH
Can't be any worse than the sheep smell in my shop after spraying FF haha
2,215
Hydrotreated neutral oil and Stoddard solvent. Sounds like something I could brew at home. SDS says "may release Cox, Nox, H2s and irritating vapors when heated to the point of decomposition". Lol
Looks to me to be nothing more then say motor oil mixed with mineral oil or naphtha
Mikey52
135
32
It's the best stuff I've used both on the airplane, and the farm. Just don't put it anywhere you want to paint later.
