Anyone had this happen before?? Just started on mine about 3 days ago. When you open the door, it barely grabs the fender...makes a faint pop. Close it, no contact. Looks like the top hinge had a little movement, and lifting up on it make the door not touch the fender....
Does the hinge need replacing?? I can't find a way to adjust it, or even figure out how its mounted. Doesn't look like there is any bolts holding it to the body. Is it welded?
