Do i need to upgrade my built trans?
The Kansan
Aug 30, 2013
179
Topeka, KS
Im building a short block for my truck and already have a built trans with a suncoast gmax kit, suncoast converter and no billet parts. Someone told me i need to upgrade the pump. Is this correct and what else needs to be done to make it live at 900 horse or so.
Mike L.
15,681
232
Fullerton CA
This sometimes works if you're a good Christian.
Ne-max
I like turtles
Nov 15, 2011
3,361
64
Lincoln, Ne
What pressures is the current trans producing? After talking to some certain people and seeing how cheap pumps are I would do one with every trans build. But I'm far from a pro.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Probably some gmax clutches, stock PR spring with a shim, transgo converter flow valve and a transgo jr. Which won't live behind 900hp lol
The Kansan
Aug 30, 2013
179
Topeka, KS
Husker diesel built the trans. Hasnt missed a beat so far. It has about 8k on the build i dont drive my truck much but as for the specifics i dont know for sure but ill find out for sure. Id have to log the truck to see what pressures are at its been a while since ive even looked at it.
Ne-max
I like turtles
Nov 15, 2011
3,361
64
Lincoln, Ne
Call Jess. He should be able to answer your questions. Without these guys knowing what he all did it's a guessing game.
The Kansan
Aug 30, 2013
179
Topeka, KS
Ya i will give him a shout tomorrow . I told him i would eventually be building the motor and hes the one that said i would just need a pump upgrade to get me where i need to be for that but i will find out for sure.
Ne-max
I like turtles
Nov 15, 2011
3,361
64
Lincoln, Ne
I'm sure youll need to shim your spring. To bump up the pressure then. Pretty simple. On the trans there is a test port. Need a good gauge and adaptor.
The Kansan
Aug 30, 2013
179
Topeka, KS
Ok im now curious to see what the pressure is at . Do you know what the threads are for the port and where it is on the trans?
Ne-max
I like turtles
Nov 15, 2011
3,361
64
Lincoln, Ne
Not right off hand. They are a odd odd size. I took a old plug and tapped it. The port is on the bottom side by spin on filter. If you are planning on going with that much hp it's a good idea to check pressure often.
The Kansan
Aug 30, 2013
179
Topeka, KS
Ok thanks for all the info . Learn something new everyday on here. Good to know about checking pressures.
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
It will depend heavily on how the trans was setup, but if setup properly then you'll be breaking parts before burning up clutches.
