DMax Lingo
In2Trux
Feb 26, 2010
North Bay, Ont.
I'm kinda putting myself out there and showing you all, how much of a New B I'am.
I'm new to this internet thingamabob. And all these abbreviations are just flying right over my shiny head. :mad:
My kids helped me with a few of them, like LOL = laugh out loud. TTYL = Talk To You Later.
I guess you guys get the idea.
I'm shopping for a truck.
I'm here to learn more about them. And I've been here for a while. And have learn a lot so far... But on some of the threads, I just get completely lost.
Can somebody help me and start a Dmax Abbreviation Dictionary :thumb:
MPI = ? = Maximized Performance Inc
HTT = ? = High Tech Turbo
VVT = ? = Variable Vane Turbo
LMM = ? = 4th Gen Duramax Motor
FPRV = Fuel Pressure Relief Valve
As more abbreviations come available they will be added to the Abbr. Dictionary
Thanks gang
KEVINL
1,431
Phoenix, AZ
MPI= Maximized Performance Inc
Makers of Duramax twin turn kits
HTT refers to High Tech Turbo
A 66mm S300 based turbo for the duramax
VVT= Variable Vane Turbo
is a turbo that is able to move vanes inside the exhaust housing to spool up quicker and they open back up at higher engine speeds
LMM is the 4th generation Duramax motor it is basically a LBZ with a Diesel Particulate Filter and a few other small changes
TIM Z
Screwed by 0087s
Jan 17, 2009
1,574
Navarre, OH
DPF - diesel particulate filter
Blocked- Blocker plate installed to block EGR passage of exhaust gas back into the engine.
0087- Low fuel rail pressure code.
Mike L.-- Guy you should call to build your trans!
MadMaxx61
Devilmaxx
Oct 13, 2008
5,458
Windsor, Ont, Canada
DOC = Diesel Oxidation Catalyst
They are devices that use a chemical process to break down pollutants in the exhaust stream into less harmful components. More specifically, DOCs utilise palladium and platinum catalysts to reduce the particulate matter (PM), hydrocarbon based soluble organic fraction (SOF), and carbon monoxide content of diesel exhaust
LB7 = 1st Gen Duramax Motor
LLY = 2nd Gen Duramax Motor
LBZ = 3rd Gen Duramax Motor
W/M = Water Methanol Injection
SD = Super Diesel - makes all kinds of sweet parts like SD Manifold, SD C-link and Sleeves
In2Trux
Feb 26, 2010
North Bay, Ont.
Thanks for the link McRat
Yeah that wouldn't be a bad idea to get it updated. But what's there is definitely helpful.
I looked all over the forum for something like this. Thanks man. :thumb:
Rikter
Grumpy, old, farty, funny
Jan 14, 2010
61
Calgary
Lingery
Don't forget POS = Piece Of Shiezen. As in "That Dodge Tranny is a real POS".
