DJM suspension?
SHOTZY
<"Whats next??"
Aug 27, 2008
474
melbourne, fl
Was looking at they're 3/5 drop. Is anyone on here running the djm lower control arms and launching in 4wd? They look nice just not sure what kind of abuse they will take.
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
If you get them replace the balljoints with MOOG stuff asap. Just had both mine go out within a week of each other.
Other than that i've never had any issues, i don't have 4wd but i beat the hell out of them worse than anyone else ever will and zero issues with the actual arms.
Mika
Bastardo Finlandias
Oct 25, 2008
291
Finland
DJM lower control arms in Punisher yes. Been in 5 or so years, but very low miles with it.
Ryan T
1,007
CA
ive been abusing mine for over 6months.. launching in 4wd on nitto NTO5Rs... 1.65 60footers.. no problems yet!:thumb:
Ryan T
1,007
CA
Was goin to use ranchos all the way around just not sure what size. You have the control arms on the Punisher?
ranchos rs 9000 are my next step..you will also need to build taction bars, got pretty bad wheel hop with out them.
SHOTZY
<"Whats next??"
Aug 27, 2008
474
melbourne, fl
Great info from all of you! Thank you. As you can see from my sig that I'm makin some changes.:D This has been a tough decision to make but I'm lookin forward to it. I'll take before and after pics and post them when I finish. Motor stuff to follow as well:)
Dudgy
Runaway
Jun 1, 2010
416
Alberta
I also run the 3/5 lowering kit on my racetruck, 40 passes on the truck and everything is holding up great. Also run cognito traction bars in the back, and racho 9000 shocks all around. I'm very happy with my suspension setup right now, launches great. And i run on slicks, 1.60 - 1.65 60footers
SHOTZY
<"Whats next??"
Aug 27, 2008
474
melbourne, fl
Thats the same exact set up I want to run. Good to hear. Trying to figure out the part number for rancho right now.
05chevy
1,086
What size slicks? Would I be able to get my 30x14s under my truck?
Dudgy
Runaway
Jun 1, 2010
416
Alberta
hondarider552 said:
Only problem I see lowering a truck is the negative CV issues. I broke/snapped off 3-4 cv's when I lowered mine more.
Ya i still have my torsion keys bolts around the same as stock, don't wanna lower it much more because of the cv angles, so far so good, i've got a spare cv axle if one blows on me at the track, maybe i'll get another spare just in case they both go out at the same time lol
SHOTZY
<"Whats next??"
Aug 27, 2008
474
melbourne, fl
I planned on running the m&h 31.5x12x16. Hopefully these fit. As far as the cv angle, I don't mind a slight negative angle. My guess is even with 9000's the front is going to lift a little. Only my guess though.
Mika
Bastardo Finlandias
Oct 25, 2008
291
Finland
I have same tires. They will fit, but you have limited turning. I dont remember what et my rims are.
Dudgy
Runaway
Jun 1, 2010
416
Alberta
yup definitely gonna lift, mine are on the stiffest setting all the way around, if it still lifts with the QA1 coilovers i'm gonna go with limiting straps
Dudgy
Runaway
Jun 1, 2010
416
Alberta
I'm not sure exactly how much it lifts but too much for my likings, if i look at my tires they're wearing on the outer edge because of the positive camber when the frontend lifts up.
