Anyone have the link to the tutorial that shows you how to modify your regulator? I need it for a buddy thank you
This one?
http://www.dieselbombers.com/chevro...53-cp3-modifications-you-can-do-yourself.html
I wish someone would show exactly how to get that "cap" off the end of the barrel to get the valve out. I destroyed a perfectly good LB7 reg trying to get that cap off.
Be very sure that there is no dirt or debris in anything.
"very"
When you say "very" does that mean a lot or a little?
x2 im going to add 30 over tipsto a stock motor that breathes very well but i still have the stock cp3my question is when do you start modding the cp3 items im running twins with stock injectors with a 160 gph lift pump is it worth it for me
better rail pressure means more power in your case
