DIY lift pump plans anyone?
Shieldsinc
On a Time Out
Apr 24, 2012
321
Anyone got any pics or plans to do a DIY lift pump. Say a pump w cat water separator or something. Already have cat filter under hood (udp) adaptor.
Big Chris
2 Duramaxes> 1 Duramax
Mar 30, 2010
361
46
Rives Junction MI
I took some ideas from Burn Down's thread and added some of my own. I used Kennedy Twin lift pumps with hd pickup. I ended up using napa filterheads with a napa water separator and a cat 750 filter. If you want to use the cat waterseperator use the cat filterhead. The napa filterhead( iirc 4770??) is 1-14 thread but it is too small and the water separator is too big to seal on it. I like the idea of the cat filters but the nearest dealer is an hour from me and napa is 15 minutes...
Big Chris
Mar 30, 2010
361
46
Rives Junction MI
I didn't take any pics but I guarantee you Scott's looks better. I'm an electrician not a fabricator or machinist and just used hardware I
had laying around to build brackets to hang it off of. I try to take some in the next couple days.
Kappa9012
MAN.... I Broke it again.
Aug 5, 2008
694
Peoria Il
FYI, I'd stay away from the plastic bowl'd cat water seperators... the metal one's are coming out, or are already out I can't remember. You'd be surprised the amount issues we have with those water separator bowls.
CarolinaHD
969
NC
just did a write up on this exactly what ya need. i went off burn downs thread too
After several trials and errors, I'm finally finished with my fuel system upgrades
Big thanks to "Burn Down" from DuramaxDiesels with the initial write up.
Specs on the system: Kennedy twin pumps with the billet pickup and 5/8'' supply lines. Powered by his harness.
Twin CAT filters with 10 micron water seperator and 2 micron final filter. The filter heads are from CAT as well. They use -8an fittings and i ordered mine from summit.
I fabricated a bracket out of some 2x2" angle iron, 3" flat stock, and 1 1/4" square tubing. Make sure to use hose rated for fuel and NOT regular heater hose. It will begin to sweat and droop. The check valve is from lowes and lists for $14.99 but the lady ran it up wrong and i got it for $9
Parts List:
Pumps of your choice
Bracket for filter heads $20.00
(2) Cat #195-1068 Filter base $81.80
(1) Cat #326-1642 Water separator $33.95
(1) Cat #343-5527 Fuel bowl $22.50
(2) Cat #1R-0749(50) Fuel filter $37.16
(1) Lowes #61252 3/4" Check valve $14.99 (They want $100+ for one from summit!
Various -8an fittings for filter heads ~$50
(2) Lowes 3/4" MPT to 1/2" barb fittings $4.42
(10 or so) Hose clamps $5.00
5 Feet of 1/2" Fuel rated hose $8.00
(1) Dayco #71359 (ONLY IF DELETING $8.99
STOCK FILTER HEAD) Total: Around $300 plus a lift pump.
Theres others stuff like nuts and bolts and drills bits but that's all up to you. I listed 2 fuel filters because its smart to always carry an extra with ya. I'm sure it could have been done cheaper with using Baldwin filter heads but I am satisfied with my custom setup
Anyways on to the pics!
Pumps mounted on the heat shield of the tank
Check valve
no more leaky stock bs!
dayco rubber hose
CarolinaHD
969
NC
i rounded up all the numbers and its about $300 with tax and all. It can be done cheaper using baldwin filter heads and water separator and bowl etc
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
I'd like to do a setup like this with a stock filter head delete and also move the ficm (on my lb7). Did you keep the factory fuel line disconnects or run 1/2" line clear to the cp3?
Ive done it both ways Wayne if your moving the ficm i would probably run 1/2 from the lift pump to the ficm and 1/2 out to a fuel block and then to the 2xcp3 if its on BGD.If you talking the blue truck i may be inclined to use the stock line.The fuel blocks ive used have an 1/8 plug in the top of them that you can insert a fuel presure gauge as i have done oe put in an 1/8 plug which can be used for bleeding.Also the fuel blocks have 3/8ths out and 1/2 in and i found 3/8ths fittings for the cp3 from parker so the cp3 gets some nice flow to them otherwise have you seen how small the supply gets down to for the cp3?like 1/4 or 5/16ths.
