LB7: Disable Low Fuel Light
Sep 10, 2008
1,072
Morehead City, North Carolina
Low fuel light stays on. Very annoying. Probably bad sending unit. Don't care to spend $$ to fix. How can I disable the Low Fuel DIC light? I've tried disconnecting the sending unit wire harness. There must be a way to delete the input signal that illuminates the Low Fuel light.
13,736
806
In the section that lets you scale the sending unit to calibrate the gauge, just enter 26 in every cell. It will always show you have a full tank, but the light will be off. It wouldn't be any worse than always showing you are empty.
3,732
300
I love abusing EFI for this kind of thing. I have a crack in the pickup tube so anything below 1/4 tank sucks air, and kills the truck. I just rescaled the gauge to read so 5 gallons is empty. You wouldn't know my gauge wasn't stock, except when you fill up with the light on and only put in 19 gallons... :roflmao:
paint94979
Beer Nazi
Sep 18, 2006
11,715
37
Haha thats funny right there
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
If the sending unit is causing the circuit to go open it'll probably be setting a code, something around a p0463 I believe. Try shutting off that code and see if that fixes it.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
You sure its not supposed to be like that? Mine goes on with 6 gallons left on a 26 gal tank
Sent from my PC36100 using Tapatalk 2
3,732
300
It used to die with 1/4 to 1/8 on the gauge, usually right as the light came on (for the irony?). Now, I can run it until range reads "LOW" and the needle is below the E and it won't die. If I fill it up the moment the light first comes on, I put on 15 gallons or so.
Sent from my Galaxy Nexus using Tapatalk 2
