I was under the impression they went on top..? I thought for crawling they put them on top not bottom for clearance?
well i guess it depends on how that pic was taken. i ASSumed it was bent forward as if under the truck but it could be bent up too lol
That pic is taken as it should sit under the truck. It's bent up, and forward too. I flipped it over to weld it outside of the truck. That is a tensial truss to counter act the bend up. It now has tie bars on the back of the lpw cover that run to backside of where the tire is at. That's tensial for the bending forward.
doesnt matter where they go as long as it achieves what your after. the truss on my tracker axle will go on top to support the tubes as well as provide support to the upper link. there will also be a back bone brace that goes across the diff cover. no bottom brace to stay out of the rocks but the rest should be plenty for hitting whoops under throttle and keep the housing straight.
aaahhh. if you can span the tensial truss across the diff cover, it will really stop any forward bending (if you wanted to over build)
So you build it opposite of the bend/stress direction sorta?
Guys, thank you very much for this info. Ive got to get my 4 link brackets welded to my axles (and pig to axle tubes) and have been wondering what procedures and supplies to use, so when I take everything to my welder Im at least slightly intelligent about it.
Question: Should you use some sort of bracing to help prevent warpage?
Corbin, the rake I welded with my little flux core machine is still in one piece. Frame on the lawn tractor hasnt re-broke either. :hehe:
If i do that it will be with a strap of steel. I don't want to loose any ground clearance more than the bottom center of the diff really.
Ohh I have had these the last year for my forward bending. That damage was done long time before this.
thats pretty cool design!
The only covers worth buying imo. They also have studs that run through press up against the differential carrier straps
this very much depends on what it is you are welding and how long of a weld it will be. if he is a competent welder and you are doing a truss that welds on the majority of the axle tube/housing, it should be done in short length and letting the housing cool before continuing on. it could take a few days of this depending on the truss and how much area of continuous welding. it is best this is done on a jig that will keep the housing from warping but not everyone has that ability/tooling. if you have the chance to find someone that can check its straightness and bend it back straight after adding all the stuff you need, i would take advantage of it.
if the welder takes his time, the housing will move a little but nothing i would be concerned about. if he doesnt, it will need reshaping afterward. again, all depending on how much welding for a truss is need (adding tabs and what not does not count)
Its nothing as involved as a truss. Just four brackets, 2 on either side of the 9.5" pumpkin. Thanks for the advice guys.
If the axle breaks, I'd just upgrade to a 10.5 and call it a day.
