Difference in the 01 to the rest of the lb7 Family
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
is it my imagination but are the intercooler tubes bigger?
no resonator option is kinda cool
The intake into the turbo seems bigger also?
when i install the HTT turbo should i tap it? or T off the wasegate line?
I was thinking of going into the I/C line but its so thin, And im not a welder:D
what other things are different? that i have yet to notice
funny, I wont need to flash in a 01 TCM:rofl:
9,903
149
B.C.
QUOTE]
Don't tee it. Drill and tap. I have heard of guys having issues when they Tee'd in to that line.
Besides-I know how you like making holes in stuff!!:joker:
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
26
64
Norco CA
www.mcratracing.com
I've drilled and tapped intercooler tubing for 1/8 NPT and it works fine at 50+ PSI boost.
A "SuperDiesel Manifold" is the trick way of doing it, because it has several ports.
The 01 has different serpentine belt routing, weaker headgaskets, and some say a weaker charger which I'm not sure about.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
26
64
Norco CA
www.mcratracing.com
QUOTE]
Not so bad with an aftermarket charger, but with a stock charger you can overboost it if you get it wrong.
You can pretty much block the wastegate on an HTT if you want. IIRC, the factory setting is about 35PSI.
JOHNBOY
< Rocking the Big Single!
Aug 30, 2006
2,159
Saegertown, Pa
x2 I just tapped mine before the boot that connects it to the intake neck. I mixed up some fiberglass resin to put on the threads of the fitting and screwed in. Spray painted it Red to add to sexyness of the LB7. :rofl:
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
thanks guys
im thinking Yes to the SD manifold,more ports for futre additions:D
weaker head gaskets, thats terrific:eek:
dieselson
1,544
30
Huntington Beach, CA
Oh man, I feel your woes, once again, we thought it was just a 1 time thing, we came home today, Coolant pouring out of the overflow :mad:, dang 01's :angry5::angry4::cussing::banghead::rolleyes:
WolfLMM
Making Chips
Nov 21, 2006
4,005
26
AL
thanks guys
Your building that engine anyways Right??? Use head gaskets from a different model year. Can you do that??? I have an 01 and I must say it looks nothing like a LLY. I feel like it has more power making potenial, but its a work truck.
good luck with your new truck Simon, let me know if I can help out:D:cool2:
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
im going to use tungsten carbide Gaskets :rofl:
thanks, I will be needing everyones help:cool2:
The 01's are the oldest ....:joker:
:blowme: :D
mvnvltn
Part's Limit Tester
Aug 22, 2007
463
45
Sykesville, MD
I have a brand new set of GM head bolts that have never been heat cycled if your interested. They were installed when motor #2 was built, and I put studs in before I put it in.
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
I should be able to:confused: Right?
Are the stock turbos the same,Can I sell this stock turbo to someone with a 03? I am finding different answers everywhere i look?:confused:
I'm a ball of confusion here
MaxFarmer
<--Heavy Smoker
Jan 22, 2007
1,251
45
Albion, Nebraska
From gmpartscheap.com:
turbocharger, all models 01-02 $2,244.49 $200.00 $1,683.37
turbocharger, all models, federal, lev 03-04 $2,244.49 $200.00 $1,683.37
turbocharger, all models, federal, tier 1 03-04 $1,699.23 $200.00 $1,274.42
turbocharger, all models, california 03-04 $2,244.49 $200.00 $1,683.37
I wish they had part numbers but it looks like there is only one oddball turbo on the 03 and 04's.
