Could someone PLEASE help me on this issue????
I have a 2003 Duramax with 180K miles. Problems started when my front main seal was leaking. I had it replaced and it started leaking again, but not as much as first time. I decided to change the oil and I drained out over 5 gallons!!!! It had at least 2.5 gallons of diesel in the oil!
Now I know there is a huge warranty issue on the injectors so I took it to my local dealer. They called me up and said that BOTH tests they ran on my injectors came back OK. They tested return rates and pressure, said the injectors are NOT leaking. When I picked up my truck, I talked to the mechanic... I asked him where else fuel could be leaking into crankcase. He said the high pressure fuel line under valve cover, or the low pressure line. The high pressure line would be covered under warranty but the low pressure line is not. It is a gamble for me to let them tear it down because if they find its NOT the injectors and NOT the high pressure line, I get slapped with over 12 hrs of labor.....
Some short history.... a few weeks before I had front main seal replaced, the truck started to develop a VERY rough shake at idle..... I ignored it for a week until i started seeing oil leak from behind main pulley on engine, but by this time the rough idle had ceased........
After changing oil, and putting fresh oil in it, my oil pressure began to run higher than I ever remember seeing it, about 60 psi on cold start, and droping to around 40 psi after road temperatures.......
That kept up for a few weeks now my oil pressure is starting to drop again on startup AND after driving...getting down to 20 psi while driving!!! or lower!
I have been checking oil level....its creeping up and smelling like diesel....
What else could it be if its NOT the injectors??? What are the chances that MY truck isn't covered by the warranty.....PLEASE HELP!!!!!!
Thanks so much!!!!!!!!
