Means that the fpr is getting zero volts, which is wide open. Bad plug, harness, controller
Pm sentThe hot lead (purple wire) from the controller is a direct connection to the power source you hooked the Orange wire to. Check the fuse. You can check inside the fuse holder to see if you are getting 12 Volts to the controller.
pos(+) terminal.Where are you picking up power for the Controller?
