DHD Brace with leveled truck
830king
191
Central MN
Is the front diff all tight in its mounts and all the bolts still in place? I've seen a truck with one of the diff mount bolts missing, so maybe your diff isnt in the right spot and causing your clearance issue?
Sent from my SM-G930V using Tapatalk
LBZ_Baker98
207
Texas
Okay, Quinton made it work. We had to loosen the front dif and tilt it back and re tighten bolts. Roller bearing assembly still wouldn't fit so we turned the wheel to bring the brace away from the dif. then installed roller bearing. The brace rides on the roller bearing constantly when going straight. steering is a little stiff but doesn't feel like its binding. thinking this might be due to the pitman and idler arm being basically brand new still and being really tight.
Austin17
Mar 1, 2021
I know I'm late to the conversation, but I can't find the info I'm looking for. I put a DHD brace on a leveled truck, and I suspect the idler bracket is bent. I bolted the angle iron piece to the centerlink, but when I bolt the brace to the diff, I've got to use an adjustable wrench to twist the angle iron up enough to get the brace to fit, and when I was done, my tires were toed out horrible.. any suggestions?
tjpruitt147
Sep 24, 2024
Missouri
Think about this. Why is it a lifted truck (one that uses drop brackets) will not work with this bracket and why is that I’m saying a leveled truck (op’s truck) will work with this bracket?
There is a slight slight chance the op is using a lift kit and lowered it to leveled height but 99% of the time if they purposely did that, they will say that because that’s pretty specific information and knowledge
Is there a bracket I can use with my drop pitman and idler arm?? Or any support bracket at that??
tjpruitt147
Sep 24, 2024
Missouri
I have a 04 2500hd 6.0 Gasser with a 10in fabtec a arm drop type lift with IFS and dropped idler and pitman. I'm trying to tighten everything up and it looks like most of my movement is coming from flex of idler arm and knuckle/joint
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,449
447
Central OH
Picture of the steering setup? Sounds pretty old school
