destroyed s366????
pocketchange06lbz
Jul 2, 2012
Westport MA
just tryna pick you guys brains, over the winter i built a modified pulling tractor with a lb7 duramax power plant i was running an s366 with a t4 exhaust housing but non gated needless to say the second run on the tractor it destroyed the charger???? only reason i see is no waste gate but im open to all helpfull information you guys have also in deciding what i should try to run now. still running stock fueling as well. thanks guys
5,817
if your 100% stock fueling, i dont see how you coulda over spun it. seems strange to me
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
How much boost? I may be wrong but I would think a 400 series charger would work better for your application? S466 or larger.
pocketchange06lbz
Jul 2, 2012
Westport MA
100% stock fuel just a lift pump set to 12psi im confused myself as to y it broke it blew the compressor cover clean off it like it was making 100psi which with stock fuel is impossible? the last time i looked at the gauge before it broke it was around 45psi.
jgt1982
Jul 11, 2012
tn
did you ever find out why you blow the s366 up because that's what i have and will be pulling with
jgt1982
Jul 11, 2012
tn
well I am a little worried because that's what I am running but a billet and its a fleece
