Delipping Pistons in block
Trippin
SoCal Diesel
Aug 10, 2006
663
Popping the pistons out and putting them back in the same hole with the same rings won't effect ring seal. The key is to clean all the carbon from the top of the bore before removing the pistons so you don't dmamge the rings during removal.
the4wheeler
--->(Something Funny)<---
May 4, 2008
254
Ventura County SoCal
well if you have a small router handy git your self a nice carbide cutter with a pilot barring little WD-40 or the like you would be supprised how nice the aluminum cuts just make sure you have a good grip on the router and safety glasses
that if you wanted to do it redneck style :D
dont forget to tape up the holes to keep the shaving out
or you can just take it to Guy
1,971
:eek: That is so "hillbilly redneck" that Jeff Foxworthy could use it in his act.
:D Drew, did you call Guy yet?
Josh2002cc
That Uncle
Apr 2, 2007
1,832
Maybe if you cut them in the hole, all the extra piston material will rest on the upper part of the rings and help you seal up that pitting :D
