LB7: Delay moving after sitting for a week
CoyoteHunter67
Mar 5, 2016
5
If it sits for a week or so there is a delay before moving in reverse or forward. once it gets going runs and shifts fine. think it could be the seals around the pump shaft? If is, what kind of job would it be to replace them.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
What year is the truck?
Early 5 speeds had a converter drain back valve issue IIRC. Pretty sure the trans has to be pulled to fix it.
15,681
The plastic sealing rings are defective from the factory. There could also be ware grooves in the front drum.
CoyoteHunter67
Mar 5, 2016
5
if it is the sealing rings. does the trans have to be pulled to fix it. would the rings be the place to start.
5,928
Yup. Not worth pulling imho if the Trans works fine otherwise. Just let it idle a little longer at first start up and take it easy on the throttle till she starts moving like it should. I've been told it won't hurt a thing (had this issue before)
jdlover1
437 Cubic Inches
Oct 4, 2006
538
chapanoke,nc
Both of mine does the same thing. Just put it N for a few seconds and away it goes. Use to run a self propel sprayer with a Allison 3 speed with overdrive in it and it would do the same thing put it in N for a few seconds and away it goes. I just figured it was nature of the beast
