The Benelli autos are inertial blowback with a rotating bolt, so they are simpler and easier to clean than gas-operated autos like 1100's. Yeah, less recoil than a similiar weight pump gun, but not a bunch IMO. And the Benelli's are lighter than most, so you might actually feel more recoil in the Benelli compared to a heavier gun.
There are a few things that affect felt recoil:
Padding - If not so equipped, get a decent gunsmith to install a high-quality recoil pad, and wear a padded hunting vest. This will make the biggest difference IMO, and usually makes an uncomfortable gun pleasant. No, it's not Macho, but it gets the job done.
Weight - More weight, less recoil. You want to see stars? Screw Hollywood Blvd, get an .30-06 in a featherweight configuration with no pad, or fire 3" deer slugs from an unpadded riot gun. Want to a have a great time? Run dove loads in a >8lb shotgun.
Load - More lead, more powder, more recoil. Don't use bigger loads than necessary to get the job done.
Stock design - A gun that doesn't fit you, is going to hurt you.
Action - With this, you need to compare apples to apples. Autos often weigh more than other designs (which is NOT true for Benelli's), so some of the "reduced recoil" is for that reason. Yes, the auto mechanism does absorb some of the recoil, but IMO, it's not very much. I have a Mossberg 835 pump gun and a Benelli SBE, both are 3.5" guns. With max goose loads, they kick about the same. Why? The Mossberg is 1/2 a pound heavier.
BTW - Benelli marketing fibs a little:
BUT... wait a minute. Read the fine print:
I think they added that little tidbit after customer complaints.
And this is what I found out. Regardless of their ad brochure at the time, not all 1oz dove loads would cycle 100% of the time. These are typically the "El Cheapo" per case ammo that I'm so fond of. 12ga ammo even goes down to 7/8 oz IIRC, or at least used to.
Reliable—The Inertia Driven® system never needs adjusting and will cycle anything from light field loads to 3-1/2" magnums with consistent reliability, year, after year, after year. In fact, there are Inertia Driven® Benelli shotguns that have fired over 500,000 rounds, still in the field and functioning perfectly.
Minimum Recommended Load: Use 3-dram, 1-1/8-oz. loads in all Benelli 12-ga. semi-auto shotguns
