Dec 13 Sacramento Drags:
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Believe it or not, I was actually kicked off the track in my stock LBZ (#115), single stock CP3, MPI twinned truck without any drugs:eek: IdahoRob must have some crazy tuning skills.......
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
We call that smoking out the lights. :D
You need to try and re-route the exhaust upwards if possible. I had an add-on extension that aimed up at 45 deg I would put on at the track.
Casper has a 7 second timeslip somewhere. But it was at 120mph. :D
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
I actually have a 9.5sec pass as well:D. I was hoping to let this one roll for tonight, (Thanks Pat;))! Yes, they actually booted me from the track!!!!!
I did remove the turn down and it eliminated the problem all together. With the help of Rob, I was able to beat my previous Best of 12.23@ 108.6mph, and I now own two 12.043 @ 110.5mph timeslips. Rob was a great help, and went out of his way to help me try to reach my 11sec goal. Im sure with some TCM tweeking, the truck will benifit. It was shifting @ 3200rpm and laying down on the 4-5 shift. I was able to make eleven passes and could have made 20+ if I were hot lapping the truck.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Don't feel too bad.
I went to dyno Blue, and the dyno said 600rwhp. Had the graph and everything. It's really about 500rwhp, and the dyno was screwed up.
Would have made for some great fights though... :D
ripmf666
15,123
14
47
Wentzville Mo
Congrats
I was about to cry 10's and I run a faster mph in the 1/8 and 1/4 was about to go out and burn my truck to the ground.
Osubeaver
Professional Grade
Aug 30, 2008
696
Oregon
Congrats on going faster!
What tires were you running when you ran 12.0?
Osubeaver
Professional Grade
Aug 30, 2008
696
Oregon
Nothing else on the truck is rated for 110 mph either :D
J/K I understand your concern
Aren't most AT tires only rated at 99mph? Those MTZs are probably 93?
Itty bitty teeeny weeeeny 275-55-16 M&H Drag radials on the stock PYO's. I would try the 33's, but something tells me they are more then likely not rated for 110+mph!
