dead pedal
01 crew
Dec 30, 2008
11
when i tow my toy hauler between 2500 and 2800 rpm i get dead pedal for 30 sec or so and then power comes back. usally no codes twice got engine overboost. dealership says its my exaust b.s its a 4" magnaflow.i read on this forum someone said they could flash the computer to 02 and it would help if any info im desperate thanks
2,009
My opinions:
1) Try going back to stock tune first. It could be something in the Hypertech tune causing it.
2) Check for codes. Could be Throttle position sensor, maf or something else.
3) Wiring from throttle could be grounding out intermittently.
4) Others have suggested checking air or fuel filter, but I dont think its that.
01 crew
Dec 30, 2008
11
it does the same thing without programer .i have only had a code twice and it was engine over boost most the time it does it there are no codes.changed filter and dealer has upgraded the injectors its crazy.
01 crew
Dec 30, 2008
11
yes it got better i could run my programmer in stage 2. now it will do it without again.
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
have you heard of this before? that sounds fun to find
I have, but it involved a quadzilla programmer, not hypertech and not a sstock truck. Like jon said, I'd check your TPS wiring. A bad ground or loose connection could cause something like this....
I know the NSBU can cause some funny issues, not sure if this is one of them or not..... :confused:
edit: any codes??
01 crew
Dec 30, 2008
11
just wondering if any one else has heard of dead pedal or ghost pedal ? i think gmc 2002 dmax might have a soulution waiting to hear back thanks for your input ,guys
9,905
151
B.C.
Should have no problem finding someone there! I bet you already have a few PM's offering help :D
01 crew
Dec 30, 2008
11
not yet still waiting i hope thats whats wrong sounds too easy.ive been trying to find answers for 8 mos thanks for the help
GMC_2002_Dmax
The Still Master
If you have a California truck you will need a OS from a CA/02 OS.
If you brought it to CA from another state and it is a Federal Truck I can supply the OS/15186006 Federal File.
I do not know if I have a 2002/Cali OS in my laptop, but If anyone has a 2002 in CA and can report what the segment info is then I can check or maybe they can just post the OS cal here.
