De rate / limp mode p2149 and more
Torqueshop
Sep 2, 2018
13
Just picked up a cheap work truck this weekend rust free has a decent utility box on it ran awesome drove it 2hrs home with no issue. The next day I went to drive it and it started right up but wouldn’t rev over 2k. Turned off and cycled key a few times nothing made a difference except the fuel gauge drop and gas light came on.
I limped it to my shop. Disconnected the battery threw a new fuel filter in it just to eliminate that possibility. Started it up drove it about 3 blocks and it went back into limp mode gas light etc.
Poked around the truck a bit and found the power pup under the seat so I checked the codes and got -
P0202
P0203
P0205
P0208
P0380
P1404
P2149
Cleared codes started up fuel light started working again but it was still in limp mode. Tried pumping the fuel filter a few times it was easy to pump took about 7 pumps before it was solid then i waited to see if it bled down after 45 seconds or so I was able to pump it again.
I found a few threads with similar issues but no solutions aside from adding a lift pump. I would like to fix the issue first and add a lift pump later.
Any help would be appreciated thanks
2004 lb7 2wd 3500 drew ext cab work truck package. mostly stock aside from egr delete and bully dog power pup. 214k miles
1,868
P0202 -- ECM - Fuel Injector 2 Control Circuit
P0203 -- ECM - Fuel Injector 3 Control Circuit
P0205 -- ECM - Fuel Injector 5 Control Circuit
P0208 -- ECM - Fuel Injector 8 Control Circuit
P0380 -- Glow Plug/Heater Circuit "A" Malfunction
P1404 -- ECM -- Exhaust Gas Recirculation (EGR) Closed Position Performance
P2149 -- ECM - Injector Positive Voltage Relay Control Circuit Group 2
Hmm...you didnt say it was a Cali emissions truck. I would do as Chris said. Thoroughly check the harness around the alternator. Wires can break inside their cover. "Seemed" isnt a diagnosis, its a guess.
Torqueshop
Sep 2, 2018
13
Didn’t know it was a Cali emissions truck. I was just giving it quick look for exterior chaffing or any obvious issues before I turned In for the night. I’ll tear into in the morning and give it a thorough inspection. I found a couple more forums with people who had the exact same issue but no one reported back with the fix. The low fuel light seems like an odd symptom but goes away when I clear codes comes back after a few start ups.
When I took the old fuel filter off barely a any fuel came out, it wasn’t until I had the filter on the bench and removed the WIF that fuel poured out not sure if that’s normal or not?
Budneeds2beers
Aka Mike Honcho....
Aug 25, 2016
497
Cali
In the truck did it have the service record binder? The reason I ask is when I bought mine at auction it had a very detailed record and notations/findings. Helped to diagnose a few things and let me know the service intervals. Also any extra info on the truck might help more then members here saying chaffed wiring. Maybe they would be more specific on what color or exact locations because of that information. Good luck what auction didyou pick up the truck at?
Torqueshop
Sep 2, 2018
13
That is true clearing codes won’t fix the problem but it definitely helps with the diagnostic process
Torqueshop
Sep 2, 2018
13
Will not getting enough fuel trigger those codes? I was out messing with it today and while it was running I pushed down on the filter head primer thinking it should be hard but it pushed down pretty easily
Torqueshop
Sep 2, 2018
13
Went through and checked and re checked all the wires today didn’t find any chaffing or broken wires
2,146
Unless you have a lift pump installed the primer bulb will be soft while the engine is running. Think about it. The fuel lines are under suction so pushing on the bulb will be easy with the CP3 pulling the fuel from it
And those injector codes are electrical not feul related
Torqueshop
Sep 2, 2018
13
So far only issue I’ve found is a loose bolt with what appeared to ground wire coming off it near the driver side ex manifold
Torqueshop
Sep 2, 2018
13
With how constant this is im starting think a bolt that holds the harness to the injector has backed off under the valve cover
2,146
It's happened before. But to be on all four injectors??? A bad ground, chafed wires or even a bad FCIM seems more realistic
