Danville built motor
MarkBroviak
DMax Junkie
2,141
499
Danville Indiana
1000hp daily driver will not be reliable.
Which part, the motor or the rest of the truck? Saying that you can't have a 1000hp in a daily driver that is reliable isn't exactly true. How you use and abuse the power has a lot to do with how it holds up. Other than the crank issues I have had very little issue with these motors holding up under power. Same with my personal built motor, I have put it through hell since it was built back in nov. 2012. Only real issues with it so far was a broken crank last year and when I had it apart to fix that I ended up putting my stock heads(with valvesprings and valves upgraded) back on because the ones I had on it had started cracking. While apart for the crank I installed the 625+studs to keep it sealed up. Even though I ended up with a 2-piece crank there was zero bearing damage so I just bought a new GM crank and balanced it and put it back together with out changing anything else. Besides the street miles on it and dragstrip abuse, it has some where around 200+ engine dyno runs on it from 800hp to 1400hp and probably close to 100 chassis dyno runs on it also. It has been very reliable for the abuse that I have put it through. Look at what Brett's original motors have been through and proved to be very reliable for the power level and abuse they were put through. Above 1400hp is were I think the reliability starts to become a serious issue.
Jan 28, 2015
961
Ohio
Mine won't always be turned up but when I feel the need to all I have to do is move the switch. Mark so the better studs are worth a 1000$ piece of mind in your opinion?
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Everything.
MarkBroviak
DMax Junkie
2,141
499
Danville Indiana
If you plan to make that much power then yes it is! I see what happens when you cheap out all the time and that is why we build our engines the way we do. That way we don't have worry about it! It's your money so spend it wisely! Some people's definition of "built" is not the same as mine, that is for sure!
Oct 16, 2008
948
12
Idaho
Everything.
That's seriously your response after Mark explained how he thinks it can be reliable? It would be nice if you actually backed up what you're trying to say with some experience, a well thought out opinion or response instead of a one word reply that implies you know something the rest of us don't.
CarolinaHD
969
NC
It's Brian, he's an angry little midget. How has everyone not figured that out by now?
9,905
151
Lots of trucks nearing 1000 HP these days and are plenty reliable. 5 years ago, not so much.
Sent from my D5803 using Tapatalk
