My personal recommendation is the 68/71Stg2R and if you need more then bolt an S488 over it and hold on!:thumb:
Since you are the man with this turbo and will be doing my tunning Mark, the standard arp studs will be fine for the 68mm you recommend staying in that 800hp range. And if i was to twin i would need the custom series studs correct ?
