Hi guys, im having an issue and cant make up my mind on what size turbo to run.
So run down of what the lmm is currently getting built with.
Durastar crank
Carrilo rods
Mahle race cast pistons
All h series bearings
Arp main studs
Just standard arp head studs ( i belive these will be fine for the max effort 800hp)
100% sticks
12mm cp3.
Lift pump
And built trans.
So my goal is to make 750-800 hp on a max effort tune but reliable. And daily say at 600 hp.
It will be used for daily driving,towing,4wding and racing. So what turbo out of the 2 would be the perfect match.
Also been thinking in the future about twins if i was to go the 67mm would that be fine in a twin set up
Durastar crank
Carrilo rods
Arp main studs
100% sticks
12mm cp3.
Lift pump
And built trans.
