LB7: dampers????
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
1000hp IIRC
Im running the stock one. rubber was in good shape and could not justify buying an ATI being Guy would only balance my crank with the stock dampener. 10k on it at 550hp and a few runs at 700hp
He told you he wouldn't balance it with an ATI?
Sent from my PC36100 using Tapatalk 2
5,911
if it came down to me not having the stock one, he would but much prefered i have the stock one to balance with. he had good reasoning to back it but with the abundance of knowledge i was absorbing at the time, this didnt stay retained :D
sickdiesel
Apr 22, 2010
1,019
If it is infact 2lbs lighter?:confused: Then yeah I would run one to.. My built motor that broke the crank had a stock balancer FYI..
LB7/LLY Stock 17.55lbs
LB7/LLY SoCal Super 16.55lbs
LBZ/LMM Stock 18.75lbs
LBZ/LMM SoCal Super 17.05lbs
delong_1
<< my work
Dec 5, 2008
1,282
Arvada, CO
mine only broke once. a handful of passes a full power, about 3000 total miles on the build and was usually run around a 700hp
S Phinney
4,008
Quncy, Fl
Mine was balance with the ATI damper. I haven't seen any problems.
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,781
Des Moines, Iowa
I am putting my engine back together, and I pulled the damper off to ling up the cam and crack as well as put the fronts cover on, but I noticed that my stock named had a crack in it
It is not all the way through and not quite a inch long( on the back sided). Question is this safe to use, or do i need to replace it? I just had it balance, can I run another stock one or just go with a air?
07keo02
Oct 5, 2011
399
Phoenix, AZ
The fluid damper still uses a slip fit design and is heavier than stock. This can only put more force on the weak crank pin. Ati's/socal's damper is an interference fit that helps the damper become more of an integral part of the crank, further increasing its effectiveness. This is the biggest reason I intend on going with the Ati. Guy will tell you that the fluid damper will reduce vibrations, but does so more because of weight and covering up vibrations rather than true effectiveness. I tend to believe he knows what he is talking about.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I would get a replacement same as the one that was on it before
