LB7: cylinder #7 injector flow rate is +7.
d-max joe
341
baltimore,md
After motor rebuild. i have had some issues with an injector #7 reading +7.00 area. so i tore it apart and bought a new one and its still reading the same thing with new nozzles too!. i hear a little knocking once it is warmed up or driven for awhile. only in drive sitting still. goes away when you touch the throttle.:confused:
Any ideas what it could be? i also had the old injector check and it was fine. so i cant see it being an injector. i am gonna do a comp. test on that cyl. this weekend when i have time.
d-max joe
341
baltimore,md
i have had injectors out three times sense motor was built. the first time i pulled them out was because four of them were bad,i have video of injector rates and #7 was fine. i buy four new ones and all new .60 nozzles. and everything was fine except #7 so i pulleded #7 again and replaced it cause i figured another injector went bad. but no still reading high after it warms up and the knocking sound that u can barley hears comes when it reads high +5.90 to +6.00 and up.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Check the balance rates with a TECH II first. theres a report over on EFILIVE's site about some problems with the LB7's reading the wrong injector like the LLY does.
