Bought this truck and I found out tonight, since I had an extra minute, and found out that the dsp5 switch wire was cut about a foot behind switch and 6" outside of the ecm.
Questions:
1.) is it possible for the dealer to flash a stock file back into the ecm with the pins still in ecm?
2.) Can I solder a red and black wire back onto each cut end safely and restore dsp5 switch?
3.) Would anyone like to take a stab at guessing whether or not the tuning is still on the ecm/dsp5?
Yes, I'm disappointed that the switch wire was cut, but more disappointed in myself for not noticing first and calling them out.
On a truck that has been sold "as is," is there a law about what "as is" means? As is to me should be that all of the functions of the truck should be right and run like a vehicle should operate. I've had problems with the abs system on the front right and also found out tonight that the hydroboost is lleaking just a touch inside the cab. IMO that is not "as is". I had another thread about the problems with no response.
Questions:
