looking for someone to machine a shifter lever for my ZF, would like to just have thread at the end to add a B&M or hurst shifter knob to it. Lookin for a same as stock replacement. any help would be appreciated. thanks
MIKE
MIKE
the factory shifter is a steel tube, might be tricky to weld it to a piece of aluminum
for the urethane i was gona cast my own bushing in to my shifter , boor out the threads in the bottom to a 1inch or bigger hole set in a a threaded bushing then mix up and pour in the urethane
i was also thinking just a hallow tube and fill it with some bits of foam rubber
I have a Hurst flat stock shifter in my Duramax and it works great. Did it shorten the throw? NO! Does it look mean as hell? Yes! It also make finding gears a little easier too. I ordered a flat stock Hurst stick from Jeg's as well as a Hurst super boot. The I took a one inch thick piece of nylon plastic and cut the base out the same size as the template that come with the boot. this gives it the play it needs. Then I took a round piece of round stock that was 1.5 inches around and 3 inches tall, on one end I drilled and threaded it to screw on the shifter, on the other end I notched it out so I could get a good weld. Don't forget you haft to get the knob custom engraved if you want the pattern on the top. There is a picture on my profile.
:nopic:
:nopic:
