I just finished my Custom Cat twin filter setup.
Specs. 160 GPH PPE lift pump, Primary filter Cat 10 Micron water separator, Secondary Cat 2 micron filter. Cat dozer rubber headlight isolators. Cat on/off switch with safety cover.
It turned out pretty good. Once I started plumbing it I realized I should have put the Pump at the back to shorten the fuel lines... Next one will be cleaner Reece :thumb:
