For a 700 HP or so motor build, would you use oem lb7 pistons? Why or why not? (Somewhat of a budget build)
delivered via tapatalk by your forum daddy!!
IMOP a de-lipped and coated LB7 piston will hold up fine , they will hold those power levels just fine , over 1k hp is where they make me nervous , you might also consider using the cast Mahle performance pistons , we have used a few sets , and thats what is in my race truck right now, from simple measuring they seem to have a bit more meat in the wrist pin area , and arent too much more $$ than new cut and coated LB7 pistons .
Imo they hold up fine, forever? no, but do forged pistons hold up forever? nope. I ran cast lb7s that were delipped, and had valve releifs cut for 2 1/2 years. 1 year running high 10s, the other year and a half pulling. I did crack one this year, but they had seen some stress. I havent had my engine on a dyno yet, but id say the numbers are pretty decent. I did go to forged after i cracked one, but only time will tell how long they will hold.
my truck had seen way to many high egt runs and 4 years of pulling/ drag racing. Most around 650ish hp and the last being around 720ish my pistons were stock and looked like new on top.....the other side was a different story but that was from bent rods lol. Im putting stock delipped lb7's back in
I bought a set of brand new Mahle cast cut and coated pistons only because they were an extremely good deal. I'm trying to debate on reselling them to buy forged or just keep them. I'm trying to start buying parts for a spare motor and keep it reasonably priced. Would you risk it running 1000-1200 hp?
IMOP I would not run Mahle cast pistons. They didn't seem to last longer than my stock LMM pistons. If my goal was less than 800hp I would go with stock LB7 pistons deliped and run extra piston to wall clearance.
i have faith in my lbz pistons.... 160k on them,they have seen plenty of abuse
good to know.
