Cts or gages
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
CTS! It has so many other features than a regular set of gauges does. The only draw back with the CTS is that it has to be plugged into the OBD2 port to work. So if you want to log with EFI you have to unplug the CTS to do so, or add another port.
dirtymax95
Sep 18, 2014
Cts it is, figured it would replace the 50$ switch for efi and repalce at least a 150$ code reader so definitely makes sense thanks guys
Snowbound98
148
Chicagoland
I love my CTS. Factory gauges suck and aren't as accurate even thou it reads the same sensors. I did both also, I have 5 gauges, intake boost, drive pressure boost, lift pump pressure, fuel rail pressure, and EGT. It's nice to have the code reader feature and DSP5 switch on that. Definitely worth the money.
05 LLY
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
I had a CTS until I got tired of replacing EGT sensors every month. Went back to conventional gauges that actually work.
dirtymax95
Sep 18, 2014
I have an 02 lb7 so I'm good. But yea I will eventually do both as well, I'm getting efi live Friday so I needed something so I can monitor. How come you had to replace the EGT sensors so often hondarider?
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
05 LLY
How did you do lift pump pressure on the Cts?????
05 Chevy LLY
-Extended cab short bed 4x4
-Sinister EGR delete kit
-S&B turbo mouth piece
-Sinister intake tube
-AEM CAI
-PVC reroute
-4inch straight pipe
-Edge CTS juice with attitude plus hot tuning
-PPE race plug and ported FR fitting
-33's
Snowbound98
148
Chicagoland
05 Chevy LLY
-AEM CAI
-PVC reroute
-33's
I didn't. I have autometer gauges along with a CTS. I listed the separate gauges I have. Total of 5 other than the CTS. I bought all my gauges and then decided to get the CTS for the ability to read and clear codes and because I didn't trust my water temp and trans temp on my dash.
