With all the talk about torque limiting issues and desiring to delete 2nd gear for the track, Ive tried to make a trans tune. This is for the drag strip ONLY...I wont drive it on the street.
Please review and comment on these changes:
Started with BBT stock trans tune, 15184109 operating system, 15183960 transmission ID
I have changed the following:
Comparison summary: 11:40:12 am, Sunday Jul 05, 2009
Calibration comparison between BBTstocktranstune_2ndgearlaunch_.tun and BBTstocktranstune.tun.
*Values that differ by more than 0.100000% are considered different.
D5000 "Part Throttle 1->2 Shift Speeds" 6.8750 "Different from cell: 0,0 to cell: 7,0 inclusive."
D5005 "Part Throttle 2->1 Shift Speeds" 2.7026 "Different from cell: 0,0 to cell: 7,0 inclusive."
D5020 "WOT 1->2 Shift (Speed)" 5.4688 "Different from cell: 0,0 to cell: 3,1 inclusive."
D5025 "WOT 1->2 Shift (RPM)" 50.0000 "Different from cell: 0,0 to cell: 3,1 inclusive."
D5035 "WOT 2->1 Shift (Speed)" 3.9063 "Different from cell: 0,0 to cell: 3,1 inclusive."
D5196 "Torque Limits" -39.3500 "Different from cell: 0,15 to cell: 8,16 inclusive."
H0103 "Final Drive Ratio" 7.3971 "CAL: 3.73 <-> ALT: 4.10"
H0136 "Tire Revolutions Per Kilometer" 1.1191 "CAL: 402 <-> ALT: 424"
The 5196 changes I gathered from the TCM tuning thread. Thanks Tony.
The speedo/tire changes are me changing to 275/70/16 tires and 3.73 gear.
I am not sure on the 2nd gear delete tables. When you are changing the part throttle 1-2 upshift, do you change the entire table (~100 values) to "0" or just the first couple lines? Same question for the 2-1 part throttle downshift table. I think you do them all, dont you? -- otherwise it would confuse the TCM when boosting up?
Is there anything else that needs to be changed? I do have a 2001 TCM stock tune (15175854 OS and 15175857 trans) Should I just start with that instead of the 2003 tune?
Go ahead and rip away....but keep in mind this is my fist foray into tuning....
