Crankshaft bolt torque?
2,011
It is NOT 105. No no no! I have no idea where you got that number, but please forget it right now.
You'll be snapping a pin and losing a balancer (and who knows what else) torquing it to 105.
I still have the 3/4" HF breaker bar from when I did my water pump years ago. Broke so many 1/2 bars it wasnt funny.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
The LB7 one I removed was installed by the hand of God... Had to use a 3/4 gun and 150 psi of service truck air... I'm with Tom, no f-ing way it was only 105 ftlbs.
Troysalm71
286
Bemidji, MN
Got it haha thanks for the info. You said it was 260 on all data, I figure that was more like it my Mac impact isn't no pooch. We had one other one there an didn't budge it with the other impact.
2,011
All I found for LML is:
Crankshaft Balancer Bolt
1st Step: 100 N·m / 74 lb ft
2nd Step: 90 degrees
I hate that GM uses angles.
Awenta
4,090
CT
Considering the correct torque is 74ft lbs, then 105*, you might want to start over
I think he was referring to 105* not pounds.
Just give it hell with a breaker bar. But you won't be tightening it now since the loctite set. Unless you want to take it off and start over.
Troysalm71
286
Bemidji, MN
I didn't put loctite on it I could take it off an put it in there I didn't know I had too I'll get on that tho.
Awenta
4,090
CT
Oh sorry that wasn't you that started the thread. I just put blue on it. Wouldn't do red. But it isn't necessary.
Awenta
4,090
CT
I may do it still trying to find a way to lock the flywheel to get the balancer torqued.
Where you located? If you don't feel like taking the starter out I can send you the locking tool. Or just buy one I think it's 45$
