I had my crank keyed for everything attached to the crank snout.
FYI: It's all metric stuff and I usually deal in inches/feet, well i used to until i started this build.
Anyway, sometimes metric stuff doesn't grow on trees. So 5mm x 5mm x 12" key stock cost $2.00 at Grainger, part # 5UA27.
On another note, if you decide to key everything attached, the snout is stepped. IIRC the front/end is .030 smaller than the back where the gears mount. So the keyway has to be stepped or mill the key stock to account for the diameter change (this would require 6 x key stock).
Hope this helps somebody.
