Well, it finally happened. Although it was preventable. Two Cast Oval Bowls cracked in a full on race build running well over 1000 HP. The cracks are on the outside of the piston and run from the pin boss up through the steel ring land. Most likely caused by ring stress from loss or reduction of cooling oil on these two pistons. Owner was totally unaware they were cracked while the engine was in service.
Heating just the center of the piston visibly opens up the cracks. The oil gallery in the piston acts as a thermal break if it is not kept full of oil. So when empty, it allows the center and outside of the piston to be very different temperatures. Something like double pane glass windows.
