I agree with you Caleb, but I have a question: have you seen significant damage caused by prolonged run time of a cast piston which was starved of oil supply due to a broken squirter?
Major damage. Depends on the heat you put to it, and where it broke. Piston will scuff, maybe melt with enough heat. If the tip bends or breaks you may not notice for a while or not at all if its driven easy, but if the banjo bolt itself breaks you'll see a drop in oil pressure.
