CP4 FCA Screen from Exergy
Stuntjake
Jun 20, 2013
3
As recent history as shown, running a lift pump does not help your CP4 to live. Even trucks with lift pumps from practically brand new have had failure. The best thing to do is run this PFR/FCA and use a lubricant. Even using lubricant doesn’t solve the CP4 problem. I’m glad Cummins has joined the CP4 trash with their new designed engines...
jlawles2
1,063
42
Danbury, TX
Maybe a third location between the other two. This on would angle the fitting but might allow for more clearance if needed. This area if probably 3/8-1/2" thick so more material for threads. The other locations are maybe 1/4" thick
So that pump says FoMoCo as in Ford Motor Company. I that correct, Ford makes the pump?
DeViAnS
Feb 25, 2019
House of Dracula- Transilvania
Hello friends. I want to make a bypass for my cp4.1 that fits Audi A4 2013. The lift pump from the tank does ~ 115 psi. Is it enought that, if I split de flow with an Y , one to the cp4 inlet, and other to the regulator bypass (FCA), the flow will assure the cooling for de rooler?
my pump has 180k km and it looks very nice inside, but.. who could know?
