I am in the Dallas/Fort Worth area. Doing the whole "warranty" lawsuits against GM about this rodeo with the dealer right now. I haven't gotten a solid answer.
Worst case, going to tow it if I can find a reputable diesel shop near or in Fort Worth or Dallas. Thinking I will do the CP3 conversion instead of going back with the CP4 (if GM won't pay for repair). The wierd thing is in his quote he didn't have injectors. He said it didn't make it into the engine... don't understand how either of those are possible if the rails are getting replaced.
What about the fuel tank... does it need to be dropped and drained?
Thanks for the replies.
Usually the complete fuel system is either cleaned or replaced, tank / lines / rails / injectors etc. Because the pump returns fuel to the tank constantly, once the CP4 eats itself, the metal ends up everywhere.
There have isolated cases of guys getting their insurance companies to cover the repairs, if you are out of your warranty window. (If you can prove you were sold bad fuel, pretty rare, but it supposedly has happened.)
If you stick with a CP4, at least install the exergy system saver on the new pump.
I converted mine to CP3.
Job is not too bad, just time consuming. Most conversion kits require the truck be deleted, because the CP3 and EGR stuff will not fit on the same motor. I guess there are a couple conversions that do not require it being deleted.
