CP4 Conversion kit
BigTex1968
LMM's are the best.
Jun 12, 2013
22
Corsicana, Texas
What’s the best conversion kit for the money. I’ve got a bud that has this CP4 and want me to convert it over to the CP3. I don’t know which one is the best for the money cause I have the CP3 already in my 09. Can y’all help a brother out? Also I’ll need to get a replacement bleeder for the filter housing. Where do get that?
1,994
If you'd google it, youd see prices for the Fleece or S&S kits are all over the place. I would check with @Bdsankey
on what he can get the kits for and go from there. Same with the fuel filter housing parts.
4,232
1,337
There are quite a few kits out there that's for sure. I've had the best luck with SDP, Fleece, and S&S kits. Out of all the kits I've installed labeled as "tuneless", the only ones that have actually been that way are the S&S tuneless kits.
I was at a wedding this weekend so my time was limited, I just replied to your messages.
5,966
S&s would be my suggestion. Just did one in a 2015 LML. Runs just like stock. Josh is a vendor for them and I believe Brad can get them too
4,232
1,337
My personal opinion is if you're seeing metal in the rails I would replace everything. It's the safest bet.
He could do just a pump and clean everything and take his chances (I would do a lift pump still) but if he has injector issues later it wouldn't be super surprising. The unknown is how much metal has gone through them already.
Reactions: gmc502 and 2004LB7
ikeG
Oughta Know Better
Apr 19, 2011
2,472
152
Western PA
www.facebook.com
What did you have to do with the other "tuneless" kits? I have a guy that wants a conversion but has his own cp3, and it looks like I can't get the s&s kit w/o pump
4,232
1,337
I had the customer source emissions compliant tuning from someone like PPEI/Duramax Tuner.
5,966
The regulator for the cp3 is special for the tunless kits so the ecm can run it via its voltage scaling.
