CP3 To Water Pump Mounting
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
Rob do you have the block filled? Are you running water through each head and returning separately to the radiator?
Sent from my XT1080 using Tapatalk
We are doing same on 3.0 truck, remove blocker plate on right side top of rear engine adapter. We flow one into front of each cylinder head, one comes out on oil cooler side and other comes out near starter on passenger side.
IdahoRob
Jun 5, 2007
1,151
Still only doing a half fill on the block (up to the freeze plugs)
On the left side, I run water into the pump and then into the coolant port where the oil cooler is on the left side and out the head to the rad.
On the right side, run water to the second pump, then to the trans adapter plate (welded a fitting there) and out the right head to the Rad.
