Cp3 shaft taper
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
Does anyone happen to know the taper of the cp3 shaft off hand?:D
Thanks Guys,
Wolf
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
Yeah I have the angle. The offset will be different for the different kits out there, keep in mind.
I got the taper from a cmm, so it’s a starting point. Start with that and make a master shaft to test fit your cp3 gear on, you may need to tweak the angle slightly to make the taper lock fit perfectly. I’ll reply to the PM shortly
