First off, I am working on a 01 ECSB. I have a check engine light on. It comes up low rail pressure. When hooked up to the efi, at 2000 rpms my desired rail pressure is 12,078. My commanded rail pressure current is 1,241.
The check Engine light comes on and goes off at random. The truck still has lots of power. I just replaced all 8 injectors with Bosch injectors from Merchant Auto.
I believe the truck sat for awhile before I picked it up. Not sure if that would cause the fpr or the cp3 to go bad. When the check engine light is on the truck sometimes feels sluggish. When the light is off it has lots of power and sounds good. Not sure what direction to go. Could use some help. Thanks
