Hey fellas, so I finally got my truck back together after doing the cp3. Before I buttoned everything up, I thought it would be wise to do a quick return flow check. Pulled the return line from the top of the new pump, cranked for 15 seconds, and sure enough, free flowing fuel. I finished reassembly for a test run and as soon as I got to about 50mph... It throws the 1093 code. It also is throwing 0238 which is "boost pressure sensor high input". I just replaced this sensor since I broke it off removing my cp3. The old one was completely full of soot.... All my injectors returned less than 2 ml of fuel after 1t seconds of cranking, so the excess return fuel is coming from the cp3?... Fresh reman pumps typically fail? Could there be another culprit? PLEASE HELP
