Wondering if anybody can help with a CP3 electrical issue. Coming off the engine harness there is a three pin connector (harness side), to the CP3. One pin should have 12v.(it does), the center pin should have 3v. (it does not), and the third pin should have 0v. (it does). The center pin that "Should" have the 3v. Signal has been traced back through the ECM. The ECM is not showing the 3v. Signal. The ECM and FICM were swapped out to see if the issue was either one, still no 3v! What else tells the ECM that it needs the signal? The truck has a dual CP3 kit, but it has been disconnected, and removed from the loop. Rail psi. Is all over the place very fast from 5K-26K psi. Any ideas?
