Could use some help! ? Injectors
michiganmax
first dirtymax
Mar 29, 2014
Traverse City
Ok I have run the truck for a week. At first a slight injector noise, slowly got worse. Today I put 150 miles on it, when returned to town I noticed sitting at a light the truck would run a little rough, like it was missing.
I stopped and checked the oil, to find there was a very little sign of oil and more fuel.
I would assume that it is coming from one of the injectors I did not change.
When I looked under the truck I could see oil slung down the transfer case and drive shaft.
I am pretty sure it's coming from the breather tube.
So my question is, would a bad injector cause the oil to come out threw the breather tub?
Dozerboy
4,918
497
TX of course
Yes once you fill the crank case with fuel its going to come out somewhere
Sent from a ditch being dug near you using Tapatalk
michiganmax
first dirtymax
Mar 29, 2014
Traverse City
Can you get a fuel leak by over tightening a injector line or a return line? And will that make a injector sound like its bad?
whytry
Oct 11, 2010
282
No offense but stop what your doing and save money until you can afford to do the job correctly.your just digging yourself a hole.. All the seals need replaced and the Fasteners need torqued
whytry
Oct 11, 2010
282
With OEM parts? And were the lines inspected for nicks and imperfections and did you tq them correctly?
michiganmax
first dirtymax
Mar 29, 2014
Traverse City
Yes OEM parts, Bosch injectors from merchant auto. I soaked the injector lines in clr, then blew them out. I did not inspect for nicks and imperfections. I just found out that some injector line seals go bad, and that could cause a injector noise and fuel in the crank case.
