Copying Tunes
03-GMC
Let there be light!!
Mar 26, 2009
485
SLC, Utah
So know i have EFI and i want to copy some PPE tunes. How would i go about doing this? Would i do it the same way i copied my stock tune or is there more invloved?
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
If the PPE tune is loaded into the ecm, do a read with EFILive and once complete save it as PPE tune.
03-GMC
Mar 26, 2009
485
SLC, Utah
So load the tune go to Read Calibration Data from PCM go throught the 2 minute process and the 15 second key off cycle then save as PPE tune (Or whatever i name it) Same process as what i did last night when i sent my stock tune to Rob?
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
correct me if I'm wrong, but you need to save both the ECM and TCM tune files with each PPE tune that you load on the truck.
03-GMC
Mar 26, 2009
485
SLC, Utah
Why would you have to copy the TCM files? I dont know much about this stuff i am just starting out.
03-GMC
Mar 26, 2009
485
SLC, Utah
Ok good cause i dont know how to copy the TCM files yet. But just so i have it right its the same way i copied my stock tune? If so it should be pretty easy
S Phinney
4,008
Quncy, Fl
Yes just load into ecm and copy and save. You will see a copyright warning each time you pull it up though. It would still work if loaded unto a truck and ran. As far as I know PPE doesn't program the trans parameters. A lot of shifts characteristics are contolled by the torque tables in the ECM.
03-GMC
Mar 26, 2009
485
SLC, Utah
I have a friend that is selling his PPE hot+2 and i convinced him to let me copy the tunes before he sells it. Right now i am waiting on my tunes from Rob and i am running stock i want a tune i can run until i take it in to get the trans built. The stock LB7 is a gutless pig
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
wow. just wow.
03-GMC
Mar 26, 2009
485
SLC, Utah
Nope Robs tunes are staying with me! Plus its just a low hp tune until i get my other ones i dont think its that big of a deal to use one of their tunes for a week.
