cooling system
bluepittsrace
bow ties or nothing
Jan 8, 2014
circleville,ohio
Did you drain the system completely when you did this and does your heater work when you get it warmed up? these engines can be a bastard to get air out of sometimes.
Did not drain system and heat works fine had solid hooked up on 2 hour ride and double checked temp gauge factory is little off but not much truck never got above 180
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
I've never had trouble bleeding the air out of a Duramax. I just pull the little bolt on top of the thermostat housing and fill it until coolant starts running out. Then I put it back in and fill the tank until it is full. Once it heat cycles once, the coolant level will drop, and I usually have to add a little. I've never had a problem doing it like that.
Yep I do it the same way and have had two that didn't seem to want to let the air out. but most of the time i've had no issues.
13,746
821
I have tried to bleed system a few times through the weep hole and still builds pressure as for the mention of head gasket I've done combustion test 3 times and get negative results on everyone just gets me going I've built several motors gas that is this being my first diesel sucks not knowing anything about them
I've never been able to get one of those tests to show a positive for combustion gas even when I knew for certain the head gasket was bad. I know others have had good luck from them, but I have not. I wouldn't take that as a for sure sign that they're not bad. Does the coolant system stay pressurized overnight?
bluepittsrace
bow ties or nothing
Jan 8, 2014
circleville,ohio
well im another lly owner doing head gaskets any good recommended shops here in central ohio to direct me to and is there anything else that might recommend doing while its down keep in mind its work truck not toy
ironmax
chock full of goodies
Jul 7, 2010
502
27
Col. Ohio
Sorry didn't read. Try layfayette injection and turbo. Ask for Shawn. He's a Cummins guy but works on anything. Located near london
Sent from my HTC6500LVW using Tapatalk
bluepittsrace
bow ties or nothing
Jan 8, 2014
circleville,ohio
ok quick update and question pulled truck in to start the tear down and was cleaning truck out to be able to put parts in bed and seen 2 empty gallon jugs of green antifreeze I called my driver he said when it rubbed hole in the hose he repaired all they had available was green so he bought it and topped it off with green now I know your not supposed to mix it but would it be causing any of my these issues before I do a tear down
WVRigrat05
Wound for sound
Jan 1, 2011
3,081
French Creek, West Virginia
I mixed all kinds of junk when mine head gaskets went for over a year before I changed em. The green doesnt do immediate damage but can cause corrosion after time. Also like Josh said that leak down test isn't really accurate, Had mine done twice and came back hood both times(this was after running it almost 60k miles) and anyways, I tore it down and the fire rings on HGs's on #2 cyl and #7 were 3/4 of the way gone.
bluepittsrace
bow ties or nothing
Jan 8, 2014
circleville,ohio
does anyone have a direct number to get in contact with creature of the night ive left voicemail and email cant seem to get ahold of anyone to place a order with
bluepittsrace
bow ties or nothing
Jan 8, 2014
circleville,ohio
Well got kit from creature of the night today so far so good being my first diesel change is there any precautions anyone could think of I would much rather take ones advice than be one on here telling about my mistake to the next guy so any little tricks would be great. Also is there need to keep constant power to cig lighter for other than door key pad and radio I can reset those but wasnt sure with all the other electronics on this one thanks to any and all help in advance
ironmax
Jul 7, 2010
502
27
Col. Ohio
How's the truck. If you have any questions or need a hand, shoot me a pm. I've done a couple head jobs on dmaxs
bluepittsrace
bow ties or nothing
Jan 8, 2014
circleville,ohio
Truck back together and so far everything OK thanks to all for time and answers was a little Leary being first one but all in all wasn't bad kit with studs from creatures of the night was great had everything plus some extras that didn't take apart
