Need some info, I noticed a small spot a few weeks back of coolent and now its growing more and more, Any ideas on what it could be, I was thinking water pump, Lb7 168xxx miles
Johnny Walker: Coolant leaks are often signs of a failing water pump. Not always. I just got done fixing a pesky coolant leak on my LB7. In the picture below you will see a 3" rubber hose with two clamps on each end. I originally thought the old, scarred knicked hose to be the source of my leak as it had coolant on it. Since I had the truck apart and that little hose was in bad shape, I replaced it and the clamps anyways. Come to find out the REAL source of the leak was a bad O ring on the pipe (right side of pic) that connects the bottom of the thermostat housing to the top of the water pump. It was dripping down from that pipe onto the little hose and at times the fan would throw bits of coolant spray around in the engine compartment. Getting that pipe back in without tearing the new O ring is tricky and you can use some bearing grease to lube the ring. Hope this helps, it may or may not be your problem just another thing to check for:thumb:
We're could I have the system tested at? My buddy ussually helps me with all my work since he has a shop think he would have a system test
