coolant pipe at pass. cylinder head??
gators1
Dec 6, 2012
fairbanks AK
has anyone heard of this pipe leaking going into front of passenger side head,its behind the gigantc alternator bracket just wondering if its leaking down onto my cylinder head making it look like a head gasket leaking,still diagnosing the problem, i drove it after cleaning the area have not seen the leak yet when it cools down upper radiator hose still feels normal never had over heating issues either or added coolant,very small leak i guess...thanx guys!!!
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Has your water pump been changed lately?
X2 some members on here have a theroy that the w/p goes out right before the h/g problem surfaces due to presurizing the coolant system and alot of people have had this happen im just wondering .
Also i take it you have milky oil ?
gators1
Dec 6, 2012
fairbanks AK
lol... yes i have replaced the water pump like 6 months ago , no milky oil,not overheating, never had to add coolant..the leak is very small cleaned the area real good been driving it to see if it leaks nothing right now,and the upper radiator hose feels normal
blk smoke lb7
Nov 8, 2010
5,694
57
belvidere,ill
So the leak is on the outside? if no leak then no problem i would asume
DBUSHLB7
Team DMAX
Mar 9, 2012
2,789
Albuquerque, NM
Here is a possibility....look at my post #9. (http://www.duramaxdiesels.com/forum/showthread.php?t=44196&highlight=Coolant+leak) There is a small horizontal crossover hose you can check but more importantly, the pipe that connects the bottom of the thermostat housing to the water pump. Did you remove this pipe when you did your water pump? It can be very tricky to get that pipe back in without tearing the O ring. Not saying its your problem, just something to check for.
