That's not a flywheel access plate. It's a rear adapter block off plate. Coolant flows thru the adapter plate and into the rear of the heads. The plate behind the dp is rectangular shaped and has 2 bolts holding it down. Not sure if the dp needs to come off but it prob does. That plate has a gasket under it. Maybe faulty, remove it and take it to the dealer to get the right shadier. You will never get the correct one without the old one....
